1 - 10 of 10 Posts
I have a 66 Chevy II sedan, and the manual steering is just killing me. How much would it cost to get power steering?
check out bill'sII chevette rack and pinion conversion. I'm doing it with a power rack and have about 450-500 into it. check out some of my pics to see what it looks like on the car
Stock is expensive way to go
I would go Bill's Chevette rack and pinion if you have the guts and know-how or after market like Flaming River. I would check with all of the vendors, NNN, Year ONE, Classic, CPP, Chevy II Only, J&W, Steeroids, to see what they have to say too.
James
The factory original style is power assist, not a true power steering box set-up. The roller bearing idler arm conversion is said to help. Also, what kinda shape is the rest of the front end in?
Jeff
For a Complete setup through Part Companies, about $1000, buying and rebuilding yourself, about half that.
(Add $100-400 for "add on's" like Idler Arm Bearing Kit, Lockup kits, etc...)
-Brent Thomas
Ohio
What are the basic components that are needed? I've got a 69 and although it isn't too tough to steer manually, it does become a chore when you're trying to parallel park and things of that nature.
Is it basically just a new box and the pump itself or is it not that simple? I always figured these "lockout kits" were for 1st and 2nd gens. :confused:
Matt
The "Power Assist" is 1st and 2nd gen only.
3rd gen and up, I believe use a power steering box and would be a "power steering".
Someone will have to comment on 3rd gen and up setups, as I don't own one.
(but I believe it is just the pump, steering box and hoses ??)
-Brent Thomas
Ohio
-Brent Thomas
Ohio
Same animal as a 1967-69 Camaro; read that integral PS from Chevy. :)
I converted my 71 over to PS last year. I went with the 12:7 to 1 quick ration box from Classic, generic pump from Autozone, and of course a new PS pitman arm. Huge difference in road feel and handling!
1 - 10 of 10 Posts
