Pretty sure thats not gonna be high enough...its got a big bell housing that needs to clear.Im thinking the ramps and some blocksIf you put the cars on ramps i think it would clear it. I had it on ramps two days ago when i was putting a new gasket on my transmission pan and it looked like it could make it.
You are misinformed...knickname is slimRyan remember his nickname is LANDFILL!! there is a landfill obstruction!!:devil:oke:
oke:
oke:
oke:
oke:
ics:
I think I see your answer here Bruce... Get NOVABRO to do it!you can do it with jack stands no problem:yes: I've done it like that a bunch of times. you usually have to lift the tranny off of the jack and set it on the floor to slide it out (slide it on cardboard so you don't scratch the pan) :yes: same thing with the new one, slide it under the car then lift it a little and roll the jack under it. Don't forget to fill the torque converter before you put it in!!! and make sure the converter pops in all the way into the trans or you will never get it to bolt up to the motor. when installing the converter just Push, Wiggle and spin![]()
yes..going from a turbo-350 to a BTO 200 4r overdrive transmission...different crossmemberI'm guessing the crossmember would need to come out. Right?
