Anyone have any advice on how to pry-off the metal trim from the side window without damaging them? I need to pull mine, clean, prime and put them back on.
Thanks,
DW.
Thanks,
DW.
What trim pieces are you refering to?If you are talking about the 3 pieces(1 at the front,rear and top of side window)on the outside i don't think they come off.Anyone have any advice on how to pry-off the metal trim from the side window without damaging them? I need to pull mine, clean, prime and put them back on.
Thanks,
DW.
Hmmmmm. do you own a Chevy II station wagon? I have three of them and when I gave the advice on this post, I had just moments prior to that gone out to my back yard and taken the upper molding off of one of my wagons to make sure I knew what I was talking about.What trim pieces are you refering to?If you are talking about the 3 pieces(1 at the front,rear and top of side window)on the outside i don't think they come off.
Thanks man!! I'll give it a shove... I tried the other night, but I knew I was doing something wrong.from the outside edge and give it a good shove towards the center of the window et voila! Start with the upper molding and use some tape on the screwdriver saft to protect the drip molding.
I'm going to give this a try tomorrow.from the outside edge and give it a good shove towards the center of the window et voila! Start with the upper molding and use some tape on the screwdriver saft to protect the drip molding.
