hi
i was just curious on whats the best way to remove the front coil springs from a 68-72 subframe thats off the car and has just the wheels on it with no motor weight on it. you can literally roll the subframe around with the front wheels on it. normally i use the weight of the car and engine to remove the front coil springs with a jack under the lower control arm to release the pressure. but this time the subframe is out of the car with no enigne, whats the easiest way? what specific tool did you use? thanks in advance
