1. I have the heater box all torn apart to replace the heater core. While it is apart I need to determine if the blower works. Is there a way I can connect it to a separate power source to see if it will turn on? It doesn't work when plugged into the heater control on the dash but I need to know if the problem is with the wiring or the blower itself. Any ideas?
2. The prior owner tore out the original hi/low horns and put in an ooooga horn (kinda neat but an eyesore). I have the original horns so is there a way I can test them to see if they work without trying to reconnect them?
3. Power tailgate window works intermittently. Is there a way I can test the motor with an external power source to see if it is the motor or just the car's wiring?
The only appropriate tool for these jobs that I own are a test probe. Do I need to buy/borrow ah ohm meter or anything else?
thanks in advance!
thanks in advance!
