1 - 20 of 21 Posts
I know alot of us are thinking about doing an LS swap, but can't afford a 5.7, 6.0 or 6.2L.
Are you satisfied with power output with or without cam up grade?
Anything else we might need to know?
A stock L33 (HO 5.3) with just a tune and headers puts out between 375 and 400 crank HP. So am I satisfied? :yes: but might I want a little more later on? :yes:
Buy a wrecked trans am, camaro, escalade, truck and pull what you need and sell the rest of the parts then haul it away. I made $600 on my ls1 swap but I had to do all the work-pulling, listing, and selling. I could have made more as the brakes, rear, abs etc.. were still in the car when I had it hauled away. If I was doing it again on a budget I would do it the same way...If you look at my build you will see that the car "looked" like junk but I still sold almost $2k from the "junk" in the less than 2 weeks mostly on ls1 tech
My build started as a 5.3 but when i brought it to the machine shop they had an lq4 sitting there and they said for an additional 300 they would build that instead. So i sold my Lm7 for 300 and when they ordered the rebuild kit they ordered the one for the Lq9. So for no more money i went from Lm7 to LQ9. there are many ways to get what you want.
From a LM7 to a LQ9 for 300 bucks?! That's an incredible score!
I think a 5.3 liter will be plenty powerful. If you want more power down the line slip in a cam and have it reflashed. You be hanging right there with the LS1 guys.
There's a good article in Super Chevy about them building a "modern mouse". It's worth a read.
after you get tired of the 5.3 in there just throw a nice sized turbo in the mix.. with the right tune and supporting mods you could make some serious hp!
The L33 was rated for 315 HP. Thats only 10 HP less than the LS1 was rated when it was first put into F-body cars. It also responds very well to a cam upgrade/reflash. Another 50 HP can be found there without going very big on the cam.
I'll let you know in about 3 months. I'm putting the L33 in my blue coupe. Having driven both, you won't be regretting the 5.3 swap. A previously stated, a stock LS6 cam and a LS6 intake will really wake this engine up.
The 5.3, aluminum or iron block is a nice choice for a good reliable engine package. The beauty is, they are very plentiful and a wide variety of cost, mostly based on mileage....
T,
I used the LQ4 motor as well LS3 heads and intake and bored it out 30 over put a stroker kit in it and made 465 to the wheels!
I'm Lovin' it!
I completed my carb'd junkyard 5.3 Nova swap about 3 months and 1300 miles ago and I love it! Smooth, fast and fun. People get a real kick out of it at shows as they almost walk straight by it and then turn around to ask questions. I also get a kick out of confusing the nimrod kids at the parts store when I tell them I need a ______ for a 1973 5.3L engine :devil:
The 100% stock engine makes excellent power. Lots of fun to drive on the streets, cook the meats at will. Fast enough to get me a $140 ticket 2 nights after completion. At the track it ran a 14.3 and trapped 100MPH. Keep in mind that is with a 2.73 open diff and street tires. AND a very rookie driver. With better gears, posi, tires and a little experience I think 13.5 would be possible. BTW, a trap of 100MPG is about 300WHP. Not bad for $275 engine!
I have had my 5.3 done for a month now with 750 miles. Love it put down 300 whp and is smooth and reliable. Can't wait to do another.
Sent from AutoGuide.com Free App
I completed mine last week and finally took it for a trip to a family BBQ 100 miles away from home. Love it on the freeway! I need the guy that flashed the PCM to email me back, he changed some things that I specifically said that I needed...my TCC won't engage unless I command it on with the scan tool. And he went too far with adjusting the VE tables. I got roughly about 22.5 mpg on that trip, but it was also still adjusting the fuel trims the whole time, I watched it the whole time and fuel trims were always negative 3-5% and now long term fuel trims sit at 0% and short term fuel trim jumps positive/negative 2-3% (rich, lean, rich, lean, rich, lean).
:eek: 100mpg! WHAT ARE YOUR SECRETS! :D
My secret is to put the "G" right next to the "H". And type really fast! :D
what alternator bracket is that ?
If you are talking about my engine compartment pic then that is a .75" steel bracket I came up with to mount the an F-body alt bracket. I had to come up with something since I was using a truck water pump and no power steering.
Though now that my arms are roughly the size of popeye I am regretting removing the power steering and plan to convert back in the near future. Like over winter!
1 - 20 of 21 Posts
