I am assuming that while you are driving your car, everything is functioning normally and the engine has no issues with cruising or acceleration.
Drive your car as you would normally to experience the issue in post #1.
Shut the engine off and wait 10 minutes.
With the engine off, remove the air cleaner and move the throttle lever while looking down into the throttle bores of the carb. Did you see gas come out of the primary squirters?
- If not, check carb's primary accelerator pump for correct adjustment... or possible leaks at accelerator pump diaphragm and/or fuel bowl & metering block gaskets.
- If accelerator pump and all gaskets are in good working order and still no gas from squirters with movement of throttle lever, "fuel boil/evaporation" is probably causing your hard starting issues.
If you are seeing gas from squirters with movement of throttle lever, move to the steps below.
With the engine still off, remove the sight plugs from the side of the fuel bowls (be sure not to loose the little washers on the sight plugs)... did any gas come out of the sight plug holes?
- If so, your float level(s) may be set too high, possibly flooding the carb as you attempt to start. Adjust float level.
- If not, go to the next step below.
Push the front bumper up and down while watching the sight plug ports.... does gas trickle out of the sight plug ports?
- If so, your float adjustment is probably ok and I think something else beside "fuel boil/evaporation" is probably causing your hard starting issues.
If not, start your engine with the sight plugs still removed and repeat the steps above.
- If gas does trickle out of the sight plug ports with the engine running, your may be experiencing some fuel evaporation in the fuel bowls due to the carb getting too hot. Recommend installing a heat shield under the carb.
- If gas does not trickle out of the ports with the engine running (and bouncing the front bumper), your float level(s) are probably set too low. Adjust float levels to correct setting. Reinstall sight plugs.
Test drive car again.
