Think you guys could estimate how much horse power my 383 is going to make.
350 block .030 over
scat 400 crank
gm "x" rods
trw flat top pistons approx 11.2;1 compression
Edelbrock alluminum heads
SB-Chevy 302-400ci Performer RPM Aluminum Cylinder Head
170cc Intake Ports
64cc Combustion Chambers
2.020''/1.600'' Valves
1.460'' Valve Springs, .575'' Max Lift
3/8'' Rocker Studs
Straight Plug
Edelbrock camshaft
Operating Range 1500-6500 RPM
Duration Advertised 308° Intake/318° Exhaust
Duration @ .050'' 234° Intake/244° Exhaust
Lift @ Valve .488'' Intake/.510'' Exhaust
Lift @ Cam .325'' Intake/.340'' Exhaust
Lobe Separation Angle 112°
Intake Centerline 107°
Intake Timing @ .050" Open 10° BTDC
Close 44° ABDC
Exhaust Timing @ .050" Open 59° BBDC
Close 5° ATDC
Edelbrock RPM air gap intake
Holly 650 double pumper (I had built specifically for this motor)
350 block .030 over
scat 400 crank
gm "x" rods
170cc Intake Ports
3/8'' Rocker Studs
Straight Plug
Edelbrock camshaft
Close 44° ABDC
Close 5° ATDC
