this is a common problem on 1st.gens,take the hood hinges off and elongate the rear bolt hole towards the top of the hole,take off about a 1/8 inch more material,thats what i did to my stock steel hood setup,passenger side was always sticking up a little bit,this mod. fixed it,lube the pivot points also,adjust the rear mounting point down,front of hinge up to bring the hood down in the back,its backwards than what you would think the adjustment should be
don
