1 - 10 of 10 Posts
I've recently replaced glass fenders with factory metal, and installed hinges for my glass cowl hood. The action works fine, but when close to closing, the hood alignment is way off, maybe an inch towards the pass side. Would I bend the hinges, or try and loosen all the panels again for any additional clearance?
Discussion Starter · #7 ·
The rad support is straight. The stock hood was dead on before swapping out the fenders a while back, so I doubt it's the RS. The hinges are from a yard. I haven't tried to play with the fenders yet, but they're aligned pretty good. I'm at work today and see the photos just fine.
measure between the fenders diagonally from front to back to make sure the opening is square. you may need to move the rad support slightly to one side or the other. If the opening is square, move the hood to hinge adjustment. Hope this helps.
Discussion Starter · #9 ·
It does. Sometimes the obvious escapes you! I did not know there was adjustment in the rad sup.
1 - 10 of 10 Posts
