I just installed a 50cc holley pump upgrade on my carb. but not sure what color pump cam I should use Brown or yellow? and what is the correct side it goes on? because I installed it one way and it pushes on the pump rocker alot and if I reverse it it doesnt.
Someone on here has, I haven't though. The 50cc upgrade is just a larger diaphram, am I correct? I just run the stock 30cc on my holley double pump. Look at where the accelerator cam bolts up to the throttle linkage, I think it can only go in one way. Also they have two holes as well with a number 1 and 2 on them. The linkage it bolts to should also be marked as well. Make sure to match the #'s up. 1 to 1 and 2 to 2. I would also check the clearance on the accelerator arm spring. Set it to .007-.010 with a feeler gauge by either tightening or loosening the spring.
It's trial and error on which color cam to use. You have to experiment with them till you find one that works to your liking. I like to dial in the squirters, then the accelerator pump cams.
