how do you make hole in the hood line up with carb and what kind of carb air cleaner to hood pan do you guys use, I was going to take a threadded rod groung to a point and screw it into the carb air cleaner stud hole and close the hood to make slight indentation like center punch mark then draw a circle on under side of hood and then cut out the hole to have it perfectly line up with the carb. I will be using an aero hood scoop and scoop air filter any scoop pics or suggestions to help with the method of my madness, J
