lifetime62 said:
i got one for you how about when you drive and your light are dim and all of sudden they brighten up
It could be due to one or more things like a poor battery negative to body ground connection if all the lights dim, a faulty voltage regulator, a poor radiator support to fender connection if just the headlights dim, possibly a sudden demand of amperage and the alternator cannot supply what's needed, a poor connection here or there on a wire, and a few other things.
I had a poor battery negative terminal to fender connection and on my 77 and the headlights would dim now and then as would the dash lights and the blower speed would vary. Any item like a light bulb or DC motor will vary in brightness or speed with varying voltages. Resistive loads will do that. Items that have regulated power supplies like in some electronics will take a fluctuating input voltage and stabilize it like in newer radio displays to where even if the input voltage fluctuates between let's say 8 and 15 volts the brghtness of it does not fluctuate.
