I'm not sure where to start, but my High beams on my '67 are not working whenever I turn them on via footswitch, the footswitch is fairly new, the low beams work great, however I'm not getting any High beam power to the headlamp connectors, I'm thinking it's either the new switch or the connectons that go thru the firwall.
Its fun time:eek: Start at the switch. Check the wire coming off the switch if you have power there then trace the line and check it at every connection.
high beams not working
Its most likely your dimmer switch, but also could be the headlights themsevles where i have found the high beam blown out. If you have a battery charger take the lights out and test them for low and high that will at least rule that out. let us know how you make out
Harley
I had a similar issue on my 64. I had juice all the way down to a bad crimp connector in my harness. Problem solved.
