What's the housing casting date? That would help narrow it down (no pun intended).I bought a 8.5 axle cut down to bolt into a 62-67 but I need new brake pads, springs, brake cylinders, drums, etc... I don't know what this rear was out of to get the correct parts. Have any ideas?
Axle Code:
5PM G313 2
Hmmm... I'll see when I get home. Should the brake parts interchange through the years?What's the housing casting date? That would help narrow it down (no pun intended).
The only "PM" code I know of was for 3.23 open in a 1978 Camaro.
Here's the code on the tube. 5PM G313 2What's the housing casting date? That would help narrow it down (no pun intended).
Bought it off of Craigslist. It's cut down to stock length 57 3/4" with stock spring perch locations 43 1/2".sorry for the thread hijack, but were did you purchase it from? is narrowed down to fit larger wheels in the back? The reason I ask is I have a 63 and want to replace the rear end on it with a larger and posi unit.
thank you, Cesar.
I'm looking for the casting date. Looks like this:Here's the code on the tube. 5PM G313 2
Here's the code on one side of the diff.
Here's the code on the other side of the diff.
This is all I could find...I'm looking for the casting date. Looks like this:
K = NovemberThis is all I could find...
Original question?
Parts for brakes?
You should be able to use the backing plate and the brakes from your current car.
If it has rear disc conversion, take some pics and post. I will try to ID.
AL
I'm pretty sure they use the same brakes shoes. Everything should be the same. You can double check by measuring the drums, but If you went to the store I bet the part numbers would be the same for rear brakes for both the Nova and Camaro.
very true. GM drum brakes are simple. A good parts man just needs the drum dia and shoe width and should be able to come up with everthing. One of the most comon is 9.5'' dia X 2'' wide the shoe number is 472Thanks Al. I'm going to try and sell the rear complete(old one). A few people told me just to match the pad and drum, everything else should be the same. Any thoughts?
The guy had the rear outside with the diff cover loose, so there was a little surface rust in a few places. Smells like he gave it a coat of WD40 to cut the moisture. I just didn't think it was a good idea, but it sounds like it should be ok.very true. GM drum brakes are simple. A good parts man just needs the drum dia and shoe width and should be able to come up with everthing.
The WD40 smell is nothing.
What else are you looking to get for the rear?
Al
