I recently picked up a 9" that was narrowed and had the ends put on to accept the Explorer style rear discs. The axles have the correct GM bolt pattern on them.
I was planning on going to the wrecking yard to pick up a set of rear discs and brackets off of a donor car but was thinking that the rotor will not match up to the bolt pattern of the axles.
Does anyone make a universal style rotor that will work or does anyone have any suggestionson what rotors I should use for this?
From what I understand the Explorer ends have the large bearing but not sure what else make them different form other large bearing ends.
