1 - 3 of 3 Posts
hi currently having some dramas with my tyres rubbing on the outer fender on drivers side.car currently has 9 inch rims and 265/50/15 tyres on it.im unsure of the back space but from the back of the centre to inner rim is 155mm.looking at downsizing to a 8 inch rim for better fitment and running 255/60/15 tyres.what back space would be recommended.car is currently a 72 with a 10 bolt 8.5 diff
Just a heads up, if your rim currently measures 9” wide then it an 8” rim. All wheels will measure 1” wider than they are advertised. The reason for this is; wheel manufacturers are stating the bead to bead width. The overall width is never advertised. So, the rule of thumb is they are always an inch wider.
Example:
If you currently have an 8” wheel, it measure 9” overall. With a 0 offset you will have 4.5” of backspace.
Google home made tire figment tool.
This is an inexpensive way to nail your offset.
Good luck!
dmassey
did you see this -- "Sticky: " -- look 3 post above your post.
Sticky: Backspace, Offset, etc. Info. (Multi-page thread 1 2)
Started by novanutcase [9th-June-2011]
1 - 3 of 3 Posts
