we put aftermaket dolphin gauges in the car...is there anyway to make the factory tank unit work with the aftmarket gauges and pickup unit, or do you have to cut a hole in the top of the tank and put a new sending unit in?
so the only way to may this work is to cut the top of the factory tank and use the new sending unit? if so, does nyone know if the topo of the 62 tank is flat, or is it ribbed?The 62 sending unit is a 0-30 ohm and your aftermarket gauge is probably 0-90 ohm so it will not work correctly.
we bought a gauge set from dolphin and they all match perfectly in an aftermarket bezel, so the gauge is staying.Wouldn't it be easier to get the right gauge? Does the gauge read at all?
You should be able to get a 0-30 ohm gauge that looks exactly like the one you have now. Would be a lot easier than putting in a new sending unit and probably cheaper IMO.we bought a gauge set from dolphin and they all match perfectly in an aftermarket bezel, so the gauge is staying.
so they make a 0-30 gauge like the center one here that will work just fine?You should be able to get a 0-30 ohm gauge that looks exactly like the one you have now. Would be a lot easier than putting in a new sending unit and probably cheaper IMO.
I believe that is correct.just read soemwhere that the 62-67 tanks are all the same. however, the 65 and up sending unit is 0-90 ohm and will work with this gauge. if this is the case, the 65+ sending unit should be a direct replacement for the 62 unit we have now since the tanks are the same, and that will keep us from modifynig the tank. this true?
