I'm hoping someone with a 200r4 can help me. I just put the car back together with a newly rebuilt trans. i believe the TV cable is adjusted properly or close to it. Here is what happens:
Reverse works fine.
If I hold it in first, things seem fine.
If I am in drive, the car quickly shifts to second and then third and doesn't seem to 'downshift'. The car surges and 'lugs' along and will usually die when I come to a stop (almost like leaving a manual trans car in third gear and coming to a stop). The trans has a converter that is supposed to lock up with pressure, etc (not computer controlled).
I have played with the TV cable, but no matter how I set it (or even disconnect it from the carb) there is absolutely NO effect on the situation.
Any help would be GREATLY appreciated!!
The new motor and rear end are great, but this trans thing means I can't drive it yet!!
Thanks!
Reverse works fine.
Thanks!
