1 - 3 of 3 Posts
I just installed the wilwood 6 piston in the front and 4 piston in rear. I had before Chevy front and rear disc brakes. The front is a stainless line and not sure if I just need a fitting to go into the caliper and the rear is the rubber brake line. I just need some input on which kit I need for the rear to replace the rubber hose and what to do with the front. Attached pics of what I’m working with.
The braided hose is probably a 3 AN size. You can get a fitting that will screw into the wilwood caliper that will have a 3An male end. The braided brake line should screw onto that. You can also get a fitting that will go on your hard line that will convert it to a An size. Most brake lines that are converted use a 3AN size. I'm pretty sure the fitting size that screws into the wilwood caliper is a 1/8 27 NPT on one end and the 3 an on the other. Wilwood Disc Brakes 220-6956 Wilwood Brake Line Fittings and Adapters | Summit Racing.
The GM caliper uses the banjo fitting. You won't use it with the wilwood calipers. Just do a search for 3An brake fittings on your favorite parts place and you should find everything needed to run your lines.
Has just about every adapter you can imagine. Earls also makes them
1 - 3 of 3 Posts
