I know is a nova furom.But I gots problem with my old truck.And this is furom I go to everyday.
Anyway it's a 69 c-10.It has a 350 sbc.Vortec heads,Performer RPM,1406 carb,Hedman headers,2.5 inch hooker aerochamber mufflers.And an MSD HEI.Stock replacement mechanical 3/8 fuel pump.New lines and fuel filter.....
The truck fires right up and runs great.But if you get on it or climb a big hill the motor dies and wont refire.It also did this with a completly different engine in it.
So I bought a fuel pressure gauge and tonight I hooked it up and ran it temporarily into the cab.When you first fire the motor up it has 7 psi.Then it goes to like 14 psi.Runs just fine.(even though 14psi doesn't make sence?)
You can drive it easy and goes good.When you mash it and shift into second gear the thing falls on it's face.It wont die yet.But then if you take off again then it will die and barely restart.Also at this time the fuel pressure reads 0.I did get the truck restarted and brought it home and let it sit and idle.Along with a few revs and the fuel pressure stayed 0.
This is a brand new gauge.
How can it be running with 0 fuel pressure?Like I said that is just sitting and idling.
I am guessing my fuel pump is toast.Should I try another stocker or upgrade.Back in the day I used a stock 5/16 pump and it would still scream.Now it has 3/8 pump and lines and it does this.
Any idea's would be awesome.I have changed the whole motor.Not to mention spent who knows how much money trying to fix this problem.It's about time it gets figured out.
Please help me!
Please help me!
