OK, so just when I think I have things figured out...it turns out that I don't. I finally settled on a cam for my 406, now I'm trying to figure out how to make it work.
I chose the XE274H after a bunch of dyno simulations. To make things easier on myself, I figured I'd go with a complete kit (includes springs, retainers, and locks) Turns out that the kit springs are 1.254" in diameter...and my 492 heads are cut for larger springs. That doesn't seem like it's going to work without some pocket reducers or something. No problem, I figured I'd just skip the kit, buy the springs and make sure to get larger diameter ones. I also figured I'd reconsider the cam and put the Voodoo cam I was considering back in the running as well since the kit thing was out the window. The Voodoo cam recommended springs are also 1.254", so same problem there.
So...I'm trying to find larger diameter springs to work with either the XE274H or the Voodoo '103 cam. After staring at the Jegs and Summit webpages for a couple of hours, now I'm completely lost.
I did some measuring last night. The spring pockets are cut to 1.500", the springs that are on there currently are 1.450" OD (widest measurement I got), and they have an installed height of 1.750". The current retainers have an OD of about 1.380" (It seems odd to me that it would be smaller than the spring, but...its not that much smaller...and they were working, so...)
Questions:
1) The spring in the XE274H kit (981) is listed at 105lb closed, 295lb open. Should I be more concerned about matching the open or closed figure? I can get in the ballpark, but...not identical. Similar story on the Voodoo cam.
2) What does the different spring do to my redline? Seems like the spring would be crucial for this, yet I don't see anything in the catalogs to indicate that.
3) How come the spring rates are wildly different, yet the open and closed specs aren't off that much? Shouldn't they go hand-in-hand?
4) Is there really any difference between an advertised spring diameter of 1.500 and 1.450...or is it just different manufacturers' terms for the same thing?
5) Can I reuse my existing locks and retainers with new springs? Should I be concerned about them being 1.380" and not 1.450"...or is that the proper size for a 1.450 (1.500?) spring?
6) For my (relatively mild) application, do I really need to worry about anything aside from coil bind, installed height, and being +/-20% with the open and seat pressures from the cam's recommended spring?
7) If the cam and the spring need to be matched so closely, how do people buy preassembled heads that have the right spring for their cam?
Questions:
