i got the new 350 in my nova and tried to turn it over. it did maybe a quarter turn and then stopped dead in its tracks, talk about major disappointment:(:(. i hope some of the great minds here can come up with something. i did a full rebuild on the engine, and it turned over on the engine stand fine but i didn't have the rockers tightened right down. the only thing i can think of is that a valve might be hitting the piston because the piston is flush with the block.
please any insight will be helpful
How did you adjust the valves? If you loosen all the rockers, will the motor turn over?
i havent tried anything yet it was late last night so we called it a night im going to bsck off the rockers and see what happens tonight.i hope the cam is in the right position
i just pulled #7 spark plug and it was falter than a pancake i hope thats all:eek:
i didnt think this engine had this much comperestion its got smog heads. can anyone recomend some sparkplugs.
ok just read your new post,
piston contacting the spark plug is not a good thing thats clearence issues i can't even think of a fix
Discussion Starter · #7 · (Edited)
dosnt mater now it was still not turning over so i pulled the head and the exhaust
valve must have stuck or the timing is off the piston snapped the valve off and it cracked:mad: i guess the 305 goes back in unlill i can get enough money to rebuild again:(.....#@$*
