1 - 3 of 3 Posts
Can anyone tell me the size, or where I can get the nut that fastens the shift linkage to the rod coming out of the side of the trans? I bought a 350 trans and failed to see that it was missing that piece. Any help will be appreciated as this one part is keeping me from getting my car drive able again. Thanks
Try your local hardware store and I suggest you start building your nut and bolt supply so you don't have to run to the store for every nut and bolt you need.
Nuts!
Probably 5/16-18 or 3/8-16. Be sure to get a flat washer or a nut that has a wide base.
1 - 3 of 3 Posts
