I have a 64 nova with a heidts front end, manual steering, and used the heidts steerign hook-up kit. The only problem I have is that there is a vibration that I can feel at time in the steering wheel. Typically steering units have rag joints or soem sort of vibration reducer.
Do you think that that installing one of the vibration reducers from Borgeson will eliminate the vibration? What has everyone else done in this setup? Thanks.
That's a great question. I was just thinking of that with my Church Boys Kit.
Not that I don't like the precise input, but in Minnesota our roads are rougher compared with states that don't have a winter.
Vendor
I don't think you will see much difference with the vibration reducer installed. I does help stop hydraulic noise transfer up through the steering shaft into the column if you have power steering. If you have a vibration you may need to check your wheel balance.
Tim
