Guys I have a 62 Wagon with a Heidts SuperRideII, Wilwood Calipers and 11" rotors that Ive been building for awhile now.
Recently Ive picked up a 65 that has a Heidts MII on it that needs the brakes and ball joints replaced.
Problem is the 65 has a total different set up than the 62 and I cant find the parts I need.
The 62 has a tiny 9.25" rotor with 5 on 5 lugs. I have looked at everything from Pinto to S10 and came up short.
What rotors and pads do I need?
I believe the older MII used some Ford stuff and the new version is Chevrolet?
Also I need to replace the balljoints ,do I need a Chrysler 727 style?
Trying to get it ready for Long Haul on the Power Tour so any help is appreciated
Not that it's related, but I just discovered that Walmart, yes Walmart, sells a suspension system similar to the Heidts setup. Helix is the name brand and they look pretty sweet.
On a related note, Heidts will steer you in the right direction. Any time I've called about replacement parts they helped out. Might as well go to the source.
