I am getting so tired
of tearing apart my front end. My TCI clip for my '66 came with 350# springs that were mismarked as 300's. So they sent me 300# springs. I drove with those over 400 miles. The ride was rough, shaking fenders and topping out on dips. The lower control arms measured +4 degrees to the floor of my garage which is flat. I ordered and swapped them out for some Heidt's 275# springs and I couldn't believe the results. The car is now 3" lower than before. The Lower arms now measure -5 degrees to the floor. So I went from too high and stiff to too low and soft but the ride now matches the new rear multi-leafs. I have aluminum heads and the battery is in the trunk.
If I cut a half coil off the 300's the spring rate will go up, it will ride rougher but the height will probably be closer to correct. So my next suspension tear down will be to add some Heidt's 3/4" coil spring spacers that will arrive Tuesday. I hope this works. All I want is a decent ride with proper ride height. Now I wish I'd put in the air bag suspension at the start.
On another note, the Heidt's 275's came in bare steel not powder coated or even painted. I dropped another $80 to get them black powder coated. So I received no satisfaction from a $200 spring change. I questioned several powder coating outfits in the Denver area and they all cure the powder on springs at 400F or below. I was concerned about annealing them. My coater cured them at 385F and said he has never had a problem with all the springs he has done for years.
So I hope the spacers and 275's work out okay. I'll find out next week.
