Can I use the positive + coil wire as the hot(ignition) wire for the hei conversion?if not what do I have to do?what else is needed for the swap?
no you can't use that wire:no: It will work but you won't be getting full voltage to the hei and the car won't run to it's full potential. get a keyed hot wire off of the fuse blockCan I use the positive + coil wire as the hot(ignition) wire for the hei conversion?if not what do I have to do?what else is needed for the swap?
