hi my 455 pontiac has a aftermarket hei performance dist. it had vacum advance but removed it not trying to save fuel has perf weight and i used the timing light that advances the weight fo max power i think i worder that right correct me if wrong its been in the car for 3 years respondes very well, i was thinking to change to a msd and box what would i gain thanks for anybodys help
An HEI with a decent module and coil will give you 99% of what you'll get out of several hundred dollars worth of ignition box. In a 455 Pontiac that will never see the far side of 6000 rpm, you will see ZERO improvement. Spend your money on something else.
Yup, and thats some solid advice.. JR
Discussion Starter · #5 ·
hei vs msd
hi thanks for the advice i appreciate it oh yeah and it has gear drive i dont think the timing could get any better
