1 - 9 of 9 Posts
Wonder if anyone has a solution to sticky, dry or rusted heater cables, or for that matter, parking brake cables. They aren't on the lube list and they often get sticky or frozen. I saw online one person soaking them in muriatic acid (not a user-friendly material) which might work for rust, but can you get it all out of the cable housing and then, how do you lube them? Trying to save what I have, not buy new.
Have you ever used muriatic acid ?. I have for taking of rust but when I do it now (and it's been a few years since the last time I did anything with that acid) is you want to make it really weak to where it will take a while to take rust off but it's easier to monitor the progression of the rust removal using a weak solution. I do know years ago I mixed up a batch and it was super strong and it looked like an alka-seltzer bath with bubbles foaming up and while it did take the rust off it also did more damage to the metal.
While I have never checked into this, it seems to me that from the motorcycle industry there was a lube setup that clamped around the cable end and with pressure forced lube or whatever through the inside of the sheathing and out the other end.
A quick google search turned this up:
I was just going to say what custom Jim said, I've rode dirtbikes all my life and we lube our cables with a cable luber and cable lube. That is for cables that are covered in a nylon or whatever sleeve though, but off road cable lube would probably be a good product to use. That's what its made for and the off road stuff is made to be non tacky so dirt and dust doesn't stick to it.
I use motorex 622 off road lube and the motion pro cable luber tool
Genius responses. Thanks, Schwabie, you should save those for some of the better, nicer cars here on site. I'm trying more and more to save the parts I have and repair them rather than discard or go with some reproduction part. Had absolutely no idea that there was a pressure luber, and I'm a-get me one a them. Thanks!
63 SS convertible 67 SS 4 spd
I just sprayed mine with PB Blaster. Held a rag up behind the cable and did little sections at a time. Mine are all what I assume to be original and all now work. Especially the parking brake.
" Had absolutely no idea that there was a pressure luber, and I'm a-get me one a them. Thanks! "
I also went over & looked at the "cable luber" . . . . cheap enough , and smart idea , I'm in .
used WD-40 liberally, let it set for awhile, then unhooked from the little tiny lock washer at the attachment point which allowed freer cable movement. done deal. well, then added a few drops of regular oil, then done deal. and they were bad, totally stuck.
good luck!
-Rusty
1 - 9 of 9 Posts
