Are the head light buckets the same on 62 thru 65? I have a 62 front end and was wondering if the 65 buckets I have will work.
are you referring to the mud buckets that go behind the headlight that attach to the core support
those are the same accept the '65 uses different mounting holes than the '62-'64 and interchange
the actual bracket that holds the headlight in position is different between '62-'64 than '65 and do not interchange
schwabie
'65 headlight brackets are different than '62-64 due to how the grille mounts
schwabie
1965 headlight mounting assemblies are designed to mount the bezels (rings) differently than other models as well.
