I just recieved my new Dart SS heads. I am pulling off the smog heads on the 290hp crate and installing the Darts. The old heads have 76cc combustion chambers and the new ones have 67cc combustion chambers. I think with these new heads I should get around 9.1 to 1 compression ratio (up from 8 to 1 CR with the old big chamber heads) using a standard Fel-Pro 1003 (.041 thk) head gasket. Do you think if I used the Fel-Pro 1094 shim gasket (.015 thk) that would be too much? I am guessing that would get me up to around 9.3 to 1 compression ratio with these heads.
Thanks in advance---
the shim gasket should yeild you another .5-.7 on compression some where in there. so if you were to be at 9.0-1 with the .41 gasket than count on at least 9.5-1 with the shim gasket.
what they were saying ^^^^^
if they block has been decked i would find out how much exactly. you can go .036 from piston to head clearance on a small chevy . but i would suggest the .040 for a street car. if the block hasnt been decked do the .015, that will give you your.040. getting the tightest quinch area is key to making an afficiant combo.
Just got the old heads off the car but still have to clean everything up and get ready for the new head install.
Appreciate the advice guys.
