Stock head bolts use NO washers..... tightening sequence.. start in the middle and move out equally forward and aft...
Big Block Chevrolet
Torque Specs
Main cap bolt, 396-427 2-bolt 95 ft.-lbs.
Main cap bolt, 396-454 4-bolt (inner/outer) 110 ft.-lbs.
3/8 in. connecting rod bolt 50 ft.-lbs.
7/16 in. connecting rod bolt 67-73 ft.-lbs.
Cylinder head bolts, long 75 - 80 ft.-lbs.
Cylinder head bolts, short 65-68 ft.-lbs.
Screw-in rocker arm studs 50 ft.-lbs.
Intake manifold bolts (cast iron head) 25 - 30 ft.-lbs.
Oil pump bolt 65 ft.-lbs.
Cam sprocket bolts 20 ft.-lbs.
Harmonic damper bolt 85 ft.-lbs.
Flywheel/Flexplate bolts 60 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Bell housing bolts 25 ft.-lbs.
Exhaust manifold bolts 20 ft.-lbs.
Timing Cover 7 ft-lbs.
Oil Pan Bolts 7 ft-lbs large bolts 12 ft-lbs
Valve Cover Bolts 5 ft-lbs
Camshaft Sprocket Bolts 20 ft-lbs
Water Pump Bolts 20 ft-lbs
Temprature Sending unit 20 ft-lbs
Spark Plug 5/8 15 ft-lbs
13/16 22 ft-lbs
For thread sealent.....
I Take a firm stand on Peratex #2.. NON harding gasket maker...... Permatex UltraBlack RTV is good as well.
#2 Permatex HAS never FAILED me...
