Just swapped my good heads, camshaft and 1.6 roller rockers onto my junk 350. Fires up and runs okay, but not below 1200 rpm or so - wants to die a lot. Engine goes down the road, but has no power. Feels like the timing is way off, but it's not.
When I installed the timing chain, I installed with dot on the cam gear on top (12 oclock), instead of on bottom and pointing right at the crank gear. I didn't think it would matter because you have to spin the motor 360 around to get back to TDC if I remember correctly - 12 oclock position. Crank spins twice as fast as cam, so they should line up at 12 oclock and 6 oclock if my thinking is right. Please correct me if I'm wrong and I'll pull the timing chain back off.
I found TDC by putting a napkin in the #1 hole and spinning the motor until it popped out. Lined up TDC a few degrees later and dropped the dizzy in. Timing is at about 20 BTDC at 1200 rpm. Any less than 1200 and it wants to die. This is a 218/218 cam, so it should idle at 600 rpm without any problems.
I've been through the valves at three times. Set them cold using the pull up and down method until slack is out, then another 1/4 turn for a little pre load. Thought the valves might be too tight. Set them again using the rotate until they stop spinning method (warmed up engine this time). Set again after reverifying TDC today. Didn't really change much from the last adjustment.
I'm hearing a little clacking out of the one valve cover, not sure what that's all about. I don't think the rockers are hitting and nothing seems loose. Might just be the exhaust leaking again - but that usually sounds like a tick more than a clack. Pushrods were all spinning when I lifted the valve covers during cam break in.
Where should I look next??? Carb hasn't been touched since coming off a perfectly fine mostly stock 350.
I'm running out of ideas! Help!!!
Kev
Kev
