I put a request asking for spare discarded Chevy II oil system parts on the Parts wanted section.
I'm going to prototype an improved version of the Durango Deuce oil system that addresses some of the problems with the stock front sump system.
The pan and pickup would fit a 4 bolt main block and have a 8740 heat treated, Front sump specific 5.3" steel sleeved drive shaft, the pump would be modified for improved flow and pressure. The press -in plugs would be replaced with threaded plugs.
I guess I need to see how many people would be interested in what so I can see if it makes sense to mass produce the parts.
I won't have an idea of pricing until I see if there is a big enough market.
Some parts require tooling that has to be amortized over the volume of parts built.
Obviously business 101 says the piece cost will drop as the quantity goes up.
