1 - 12 of 12 Posts
What side is your dipstick on?
Block casting number would tell.
Al
your summit link will not work.
Post part #
That pan listed Moroso 20170 is no different than a stk pan. Waist of money IMO!
Save money and buy the summit brand for less than 50.00 to your door same pan!
SUM-G3500 Summit® Steel Oil Pans
Oil Pan, Steel, Chrome Plated, 4 qt., Chevy, Small Block, Each
$33.95
SUM-G3500X Summit® Steel Oil Pans
Oil Pan, Steel, Natural, 4 qt., Chevy, Small Block, Each
$21.95
SUM-G3500P Summit® Steel Oil Pans
Oil Pan, Steel, Orange, 4 qt., Chevy, Small Block, Each 23.95
My favorite is the Hamburger pans. But also 200.00 cost range.:eek:
Al
dipstick is on the passenger side..... right side can you give me a few pans that you would reccommend?
We need the block casting number to see if you have a one or 2 piece rear main.
Passenger side dip stick in most cases is a 1 piece rear main. BUT THAT IS A ASSUMPTION!:eek:
This is a hard pan to beat for the money!
http://www.competitionproducts.com/prodinfo.asp?number=71098
Will require this also.
http://www.competitionproducts.com/prodinfo.asp?number=72508
Discussion Starter · #7 · (Edited)
it says to check chasis clearence before installation?..... and i need another oil pump? why? is this a deeper pan?
block casting number where do i look and ill get u the number
front, back, driver sid, passenger side of motor?
If you have a 68-76 nova it will fit.
You do not need anouther pump
You need a oil pump pickup!
Your best bet is to buy the Summit brand stk pan.
Casting number location
DS on block behind the head where the transmission bolts to the block.
http://www.mortec.com/location.htm
Discussion Starter · #9 ·
okay im charging my camera so i can take a pic of the stamped number code. then imma call summit and order the right parts im going to return my fel pro gasket because it was the wrong one for my engine. it was for a left side dipstick when i have a right side motor.
Discussion Starter · #12 ·
According to Mortec it is an 87 - 95 1 piece seal block
thank you!!!! i found all the parts on summit easier!!!!!
what code did you use to crack it and how did u crack it? i was on morton an couldnt do it.
do you have any more pix of you when it was disconnected from the chassis? it looks sweet in your avatar!
1 - 12 of 12 Posts
