Before:
While I think I'm going to miss the shiny zinc finish of my 750VS, I have high hopes for the 650DP I installed today. I've been toying with it for the last week getting its baseline state setup as good as I could.
It got new fuel bowl & metering plate gaskets (changed the old cellulose ones to the new blue ones), an electric choke upgrade, new jets (71/74 as a start), new squirters (.035), and the transfer slot set to the baseline .020 setting. I didn't swap pump cams because it already had pink cams installed and I figured they were a good starting point. I even found some nice braided vacuum line to play with.
After:
The new setup is almost ready to fire except that I need a new fuel line adapter (-6AN to NPT) for the dual feed line inlet. I'm not 100% sure I like the fuel inlet kit I bought. It was a cheapo Spectre unit, but I was hoping to get this thing fired today and failed miserably due to parts inavailability based on the wrong assumption that a 4150 used the same inlets as a 4160. Wrongo.
The Spectre kit is a quick-fix. If it doesn't leak like crazy, I may keep it.
I'd have gotten more done today but I cleaned up the garage first. That felt really good to get done first. Now if I could only talk myself into better plug wire routing (via homemade MSD wires) and wrapped engine bay wiring. :shh: Getting the Caltracs installed properly and setup comes first though. Today's playing was time filler until I get all of my parts & Calvert's parts to cooperate.
Have I typed enough yet??
After:
