My problem is the gen light comes on after i shut car off i can unplug it light will go off and stay off when i plug it back in any suggestions? i am no voltage trouble shooting guy but could it be like a voltage regulator? Open for suggestion and Thanks..
I had the same problem but I am using a msd ignition set up so it was actually back feeding the ignition also . If you have an external voltage regulater you need to put a diod on the #4 terminal and that should solve the problem , if you Google it you'll get all sorts of info
Sent from my ADR6350 using AutoGuide.Com Free App
