Gen I Vent Window Won't Open
1098 Views 3 Replies 3 Participants Last post by  Greg Ellis
What kind of adjustment is there to raise the vent window assembly? I rebuilt mine with a new gasket and now that it is installed on the stainless steel garnish trim the vent window is so low that the gasket interferes with the swing of the vent glass. Sure, I have tried to pull the assembly up before I tighten it into place but there is no adjustment there. It seems like a shame that everything is rebuilt and now the vent glass will not open:mad:
Greg,
Is this an aftermarket frame or an original one that's been rechromed?
The reason for this quesiton is that when I rebuilt my vent windows on my 66, those aftermarket frames are jacked up bad. The upper pivot point sits 3/8" lower than that of the original one, the frame itself sits at a downward angle in relation to the original one.
I wrote up a report to Chevy 2 Only a couple of years ago and explained in great detail on the errors of the "overseas" stuff.
The aftermarket seals work perfectly but, the rest of the stuff is not even close. If you can remember if you but the "tang" washer and plastic washer above the top end of the vent frame?
As looking from the top of the frame down to the locking nut below the vent window spring it should be like so:
Upper tang washer ( this has a lobe on it to keep it from spinning a 360 )
Upper plastic washer
Vent window frame
Lower plastic washer
Spring
Locking tang washer
Nut
If that's correct on your vent windows, then it's the frame.. Sorry.
Dan
see if any of this assists you...
http://s7.photobucket.com/albums/y258/64Flyer/ChevyII-Nova Information/Wing Vent repair/
or...
http://rides.webshots.com/album/563916466IftqdC
ovrdrive, I will check the installation of those washers. I did use the original window frame so that part of my install is OK.
Flyer, I printed the NNN article you provided and will recheck my work.
Thanks to both of you guys!
