1 - 20 of 24 Posts
I want to mount my trans, oil temp and fuel pressure (isolated) gauges under the dash. How about some pics of where you mounted yours. I was thinking under where the radio goes.
Show yer pics.
TIA,
Denis
I found them easier to see under the ash tray, plus no drilling!.
I thought about under the ash tray, but I have a single 3 gauge mount. Your individual holders look staggered. I'll have to have my wife hold them in place. I need pics.
Autometer used to sell cups to turn them when in a pod of 3. Try use one screw from the dash to hold the bracket and see if you like it. I find the monster tach too big to fit any where, I'm going to try a bracket off the heater controls. Your height you sit at may make them easier or harder to see, so trying the bracket while driving will give you a good idea. The best place I've seen them is in the AC opening in the center of the dash, but you'll need a new pad or to cut yours!:eek:
Here's the opening, no gauges though.
I run 3 guages down the left hand side where the vent normally goes, one to the left of the steering column, one hanging below that and one hanging below the center console. They hanging ones are temporary until I get my console made but everything is very visible and works well.
I also cut a hole in the factory clock plate and mounted an aftermarket 2" tach on the plate. It fits really well. I'm not a fan of big guages taking up a bunch of space.
If you look at the interior picture in my car profile, you can see my gauges mounted in a 3 panel mount under the ashtray. I used all existing holes. The gauge kit is a Summit kit and the bracket looks exactally like an Autogauge bracket:
http://www.stevesnovasite.com/forums/showthread.php?t=85848
I already have my oil pressure and water temp gauges in left side. I think I know where I am putting the other 3 now.
I did a temp mount under the ash tray as you did. I have the bracket angled toward the drivers seat for a better visual. I think I will keep it there. Nice pics. Love the wagon in the 1st pic.
That's my dad's wagon. It's a 71 Chevy Malibu Greenbriar. It's all original including the paint. It need some work but is a nice driver. The guy who was going to buy it before my dad saved it was going to put it in a demo derby:eek:. We're getting ready to redo it after Good Guys Columbus this year, I'm trying to talk him into a 496 for it:devil:
Discussion Starter #13
I have the A-pillar thing in my truck, but you have to use the small gauges.
I also had mine mounted below the ash tray. I'll be getting a Covan's dash so will be moving them into the dash area now instead. This is the best pic I could find and it was after I started tearing things apart. I used a piece of metal to attach all 3 gauges to and then I attached the piece of metal to existing holes under the dash. That way I didn't have to drill any new holes.
heres mine. My water temp, oil pressure, and volt meter are all mounted in the lower panel. Im gonna mount a trans temp gauge in there to when I buy one.I left room next to the fuse holder for my timing control. I also converted my ash tray to mount my nitrous pressure gauge and hold my push button starter.
Gauges once again...
Here's the "old school" way my gauges were installed. The only change I made was to take out the Ammeter gauge and replace it with a much more safer Volt gauge. It's right within view and easy to read.......
I'm going to use some 2 5/8" Phantom electrical gauges ( Water, Volts, Oil ) and be able to use the water temp as my trans temp as well. I've wired an in-line on-off-on switch and mounted near the center console hanging from the bottom part of the dash. This way I can monitor both without the installation of another gauge.
1 - 20 of 24 Posts
