1 - 9 of 9 Posts
they usually are a pretty smooth finish. ive never seen a small block chevy use a gasket between the oil pump and block. maybe some one can chime in on that. the 400sb maybe different.
No gaskets. Never have had a gasket on any small block Chevy. The tiny bit of oil that may get buy goes right back in the pan.
No gasket needed.
Just put a 400 small block togother.Has good oil pressure.Doesn't have a gasket.
The 400 is the same as other small blocks.....
No gasket. Torque bolt to 55 ft/lbs
1 - 9 of 9 Posts
