So my wagon currently has a Magnum 280 Comp Cam. I get like 10mpg. I'm sick of it. Here's the basic specs:
Camel hump heads
~9.5-10:1 compression
Stock exhaust manifolds
Edelbrock Performer EPS intake
Holley 600 with mech. secondaries
TH350 with about a 3.08-3.31 rear gear
What are some hydraulic flat tappet grinds that you guys use to get decent gas mileage. I had a 72 Nova a long time ago that got 20mpg with a mild RV cam that I didn't know the specs on. I would like to get somewhere around here with the TH350 then step up to a 2004R and get even better fwy mileage. Please chime in on what you think would work best. I'm also adding power brakes, so a bit more vacuum would help. I'm thinking that something in the 212*-220* @.050 and about .450" lift is what I'd need on a 110*-114* LSA. Thanks
Camel hump heads
