Roadkill Garage used hi amp relays and fuses for both starter and main power Positives from trunk batt. Episode showed diagrams and installation. Genius idea. No power in main cables til keyed on.I have trunk mounted battery in aluminum battery box. 1/0 ga weld cable goes to mini starter. Thinking of using a 300 amp AMG fuse to protect system. Has anyone fused the negative side of battery? Thank you, Lenny
Do you know what episode it was. I would like to see it.Roadkill Garage used hi amp relays and fuses for both starter and main power Positives from trunk batt. Episode showed diagrams and installation. Genius idea. No power in main cables til keyed on.
Electrically, it makes no difference on which side of the battery you put the fuse.I have trunk mounted battery in aluminum battery box. 1/0 ga weld cable goes to mini starter. Thinking of using a 300 amp AMG fuse to protect system. Has anyone fused the negative side of battery? Thank you, Lenny
S6 E3&4Do you know what episode it was. I would like to see it.
Thanks.S6 E3&4
don't tell the high school teachers thatElectrically, it makes no difference on which side of the battery you put the fuse.
No added protection. The current out of the positive terminal of the battery is the same as the current into the negative terminal of the battery. All a second fuse does is add more resistance to every circuit at the battery connections (not good), and it means when you do blow a battery fuse, you'll have to inspect both of them to figure out which one blew out first.could even put a fuse on both + and -, that would add a bit more protection
don't know that anyone said they didRelays don't protect against overloads and shorts. Neither do cut off switches.
fuses shouldn't be adding resistanceAll a second fuse does is add more resistance to every circuit at the battery connections (not good)
technically yes, especially if considering just steady state with battery and resistance, but strange things can happen with circuits with capacitance and inductance and cars are filled with both especially with modern electronics, unpredictable instantaneous currents and voltages can happen with shorts in complex electronicNo added protection. The current out of the positive terminal of the battery is the same as the current into the negative terminal of the battery
It's not a lot, but we are talking about a fuse on the battery cable here. For starter current, our 300A ZCase fuse shows about a 55mV initial spike and settles in around 30mV as long as the starter is running. I wouldn't want to double that with a second fuse. The resistance of our 300A slow-blow Z-case fuse is about 0.13mΩ.fuses shouldn't be adding resistance
Fuses are to protect wires, not to protect what's at the other end. Wires don't have significant capacitance or inductance in a DC power circuit, so the rest of your reasoning is based on a flawed assumption IMO.strange things can happen with circuits with capacitance and inductance and cars are filled with both especially with modern electronics
You should be careful about installing a jumper on the starter as this may cause run-on if you are using a PM starter.I researched mounting a battery in my trunk and found what I think is a better way to wire it. I used a Ford starter solenoid in the trunk at the battery, ran my positive cable from the Ford solenoid to the starter solenoid at the starter post and a purple wire from the ignition switch start circuit to the Ford starter solenoid "S" terminal. I believe I had to install a jumper wire from the starter battery terminal to the starter motor so the motor will spin as well as the bendix engaging. With it wired this way, the only time the positive cable is powered is when the ignition switch is turned to the start position, seemed to be safer that way. I also ran a fused 8 GA wire from the battery to the horn relay terminal, I believe, to power the rest of the accessories. The negative cable I ran from the battery to the engine block. I'm sure there was other wiring needed but that's the short version of the story.
