What type of gauges? Dakota digital has universal sender, part# sen-06-1.
That may just work. Classic Industries catalog list the tanks to be the same from 62 to 67. The 66-67 sender is listed as 0-90 ohm's. Thanks!I think a sender from 66/67 will fit the tank and is a 0-90 ohm
OH you could send me a link to that :yes:I have a 0-90 ohm 66/67 unit in my stock 63 tank. Got it brand new off of Ebay. It was cheaper and still had the brass float. Same seller has them now. $30.
that makes 3 of us that need that link! :yes:OH you could send me a link to that :yes:
I need one for the 67 n the 73 that I have....:bored:
Actually I found that the gauge that was built for 73-10 ohm. That would make it read backwards using a 0-90 sender. After a little research I found that the gauge was per-programed for the Ford/Chrysler 73 to 10 ohm. There were two looped wires on the back of the gauge and to make it 0-90 I had to cut the blue one. Now everything is as it should be. Thanks for all of the input here. MJ40'SSounds like the gauge is built for 90-0 instead of 0-90 ohms
