EZ EFI fuel pump location.
This is a short term temporary solution to the fuel injection set-up in my car. The long term fix is to install a F/I sumped gas tank.
The pump is located on the plate and is insulated with rubber lined clamps. The plate is mounted to the bottom of the trunk area mounted around the spare tire holder so when the spare tire is in place, you don't see the mounting bolts. I used some spare Dronemaster exhaust insulators for the insulation of the bracket so I don't get a constant buzzing or metal to metal contact when the pump is running. Without the tank being sumped, I can't let the tank get below 1/4 of a tank.
But, you have to remember this, "Check your state laws" pertaining to having a rear mounted fuel pump. For the track, this is acceptable but, for the street, it's a big no.
