I am tired of the constant drone of my Holley Blue Pump and would like to convert back to a mechanical pump. I have a couple questions:
1. My fuel cell, filter, pump set up is shown below. It was taken before the system was finished but you get the idea. If I eliminate the electric fuel pump will I have a problem with the mechanical pump pulling fuel through that filter?
2. Can mechanical pump be used with the regulator intended for the Holley blue? I know it's not needed, but for simplicity sake I would just like to run the fuel from the cell to the in of the mechanical pump and then out to the regulator which is mounted on the inner fender and then over to both fuel bowls. I'm thinking the regulator won't impeed fuel flow.
Any thoughts?
Any thoughts?
