I hadn't started my wagon in quite a while. I decided to start it and drive it for a bit to keep things circulated. Took the battery out and charged it overnight. Put it back in the car and cranked.....and cranked.....and cranked. Hmmmm. It's never been this hard to start that old six-banger. I figured maybe the gas went bad during the winter. Only had a quarter tank in it or so. I usually fill it before parking it for the winter, but didn't this year. So, I dumped a couple of cans of new fresh gas in her and bounced the car to mix it up good. No luck. I filled the carburetor with a syringe into the vent tube. Started right up. Purred like a kitten. (well, as much as an old stovebolt can purr) Then it died. Hmmmm. Must have used all of the gas in the carb, but not getting more. I undid the fuel line from the carb, checked the filter and left the line loose and cranked the starter. From the front seat, I could see the fuel line. Just a few spits of fuel. Hmmm. Maybe the fuel is jelled a bit some where in the line. Reconnected the fuel line to the carb. Had my son fill the carb bowl while I cranked. It would start, but run only until the bowl was empty. Repeated several times. Should have pulled some good fuel up by now. Fuel pump must be bad. Got a new pump from NAPA (had to wait overnight). Put it on (the bolts are a pain to get a tool on) and no change. Starts easily when fuel added to carb bowl. Dies when it runs the bowl dry. Crawl under the back to look at the tank and ............ the rubber hose to the tank is split open!
Replaced it and she starts and runs like a jewel (well, a cheap jewel
MORAL: If it ain't getting gas, check the lines first.
It's cheaper and quicker.:thumbsup:
