am i new to this i have had countless race/street cars that have had a electric fuel pump going to the carb, now my speed shop is telling me i need to run another hose from a bi pas all the way back to the cell. ive looked at alot of race cars and most people dont do this
There are now 2 types of systems.
Deadhead, most common and just what it says.
Tank to pump to Regulator(if required) to carb
Or a closed loop system
Tank to pump to regulator to carb to tank
The main design for the closed loop system was for fuel injection, this removes all air in the system and efficient fuel pressure control.
The requirement is based on the pump you use.
Some pump pressure valves are set by flow pressure, not dead head pressure.
A pump that is designed for closed loop and used on a deadhead will create too much pressure.
The rumor of keeping heat down by using a loop system is just that. RUMOR! The pressure valves are set the same and the pump is under the same pressure and amperage use.
Hope this helps.
A carburetor application does not require a closed loop system.
AL
