HELP High volume Fuel pump leaking oil somewhere on top not from the mounting base or gasket has anyone experienced this only leaks at high rpm under load that I am noticed what do I look for or how Do I diagnose the problem
72, 2 Dr, 383, 700r4
The hole is also handy when using a long bolt to put slight pressure on the fuel pump rod to hold it in place while installing the fuel pump.
What kind of fuel pump is it? I have had an oil leak at the fuel pump seam between the top and bottom halves of the case.
