I have a fuel pressure problem, it keeps dropping to "0" after about 10 minutes and dies out.
It will keep running if i drive it
I have a new holley (remauf.from Holley) 700 Dbl.Pump, new fuel pump,was a holley 130 Gph, now a Edelbrock 110Gph and a jegs regulator. AN fittings from the Russell fuel filter before the reg., just checked and cleaned.
I hooked air pressure to the line from before the pump back to the tank and "No" restriction
After i shut it down when the pressure drops, it will build pressure back again to about 5 lbs in 10 minutes.
Any Clue whats up????? Or what to check next??? Thanks Eric
Also i tried bypassing the regulator too, same thing happens.
